depere
Feb 08, 2021Follower
Netgear WNR2000v5 does not allow internet connection
My provider is Spectrum. I have a modem and a Netgear router. The computer works as does the TV. I am trying to set my TV to get other programs through the internet. When I start the setup, it de...
wcalifas
Feb 20, 2021Prodigy
try downloading the latest firmware for that router from the netgear.com website under the support tab and write the model number. Download the firmware and apply it manually and then try running the setup once you apply the latest firmware on the website. Les us know what happens. I would reccommend buying a newer router though since you'll get better speeds and coverage than that router you have. You could use it as an access point later to expand coverage though with that older router.
