Snaterman
Apr 04, 2017Aspirant
Netgear WNR3500v2 as third wifi access point
Hi, I recently got a new router/modem(in1) (technicolor) from my ISP. i have a second wifi accesspoint in the form of a TPLink Archer C9. I now want to make a third wifi access point in my baseme...
- Apr 05, 2017
Welcome to the community, Snaterman
Reset the router to access the admin page or the GUI then start all over.
I suggest that you change all wireless settings first before changing the IP addresses.
Before doing anything, make sure not to connect the router yet to anything else except a PC.
For the LAN IP address, set it to 10.0.0.3, copy the subnet mask and the default gateway.
Disable the DHCP by unchecking the box that says "Use Router as DHCP Server". After saving the settings, you wouldn't be able to access the page anymore since it changed it's IP address.
You may now connect the Ethernet cable to one of the LAN port. After connecting the cable, check your computer if it will get an IP address.
Snaterman
addition: in step 4, gateway of netgear is set to main router 10.0.0.1
- ElaineMApr 05, 2017NETGEAR Employee Retired
- SnatermanApr 06, 2017Aspirant
Last night i tried again, and although i think i did everything the same, it now worked (like a charm), so i guiess i did something wrong earlier.
Internet connection is available and i an see te routers setup page at 10.0.0.3.
(sidenote, my internet is very slow, but i'm still checking wether thats an issue with the isp, it probably is)Thanks for the help.
- ElaineMApr 06, 2017NETGEAR Employee Retired
Glad to hear that it worked!
Thank you for providing your feedback and marking the solution.
