fb33
Jan 16, 2021Aspirant
Netgear won' respond to used Netgear 39
Does anyone know any secrets how to get Netgear to respond? I bought a used modem/router on Amazon to my new internet service. I'm trying to re-register it so they send me a username and password. C...
fb33
Jan 17, 2021Aspirant
O.k. I'll try that. Thank you for your help.
schumaku
Jan 17, 2021Guru - Experienced User
Consulting the Quick Start Guide like NETGEAR AC1600 WiFi VDSL/ADSL Modem Router Model D6400 Quick Start Guide or again the product label on the device (convinded the default username and password is printed there) would help to start with.
- antinodeJan 17, 2021Guru
> Consulting the Quick Start Guide [...] would help to start with.
This must be some new meaning for "help". There are no "default"
PPPoE credentials, on the label or anyplace else. Unless the ISP
provides some. And, in my experience, CenturyLink (Qwest, U.S. West,
...) uses only custom, per-user PPPoE credentials.
