cj2
Apr 03, 2022Aspirant
Netgear86 Router
Need a bit of an education, looked at my router log and found the posted below. the access it to my port forward/ port triggering. It appears to be authorized access... I do have one program th...
Apr 03, 2022Guru - Experienced User
So what router model# are you referring too?
- cj2Apr 03, 2022Aspirant
R6220v2/ac1200 Smart wifi router with external antennas.
There has been some evidence of the system being accessed, with programs left open, closed, some typing left in an email sign on... more than gremlin type stuff.
I did change the my port forward ip address all together. Deleting the 192.168.1.130 address. So far no other related problems to local lans.
The above ip address is not related to the security system.
The real question is why the need for a port forward ip address all together?
There were no other obvious signs of intrusion, per the router log.
- michaelkenwardApr 04, 2022Guru - Experienced User
cj2 wrote:The real question is why the need for a port forward ip address all together?
Ask the people who told you to set it like that.
- cj2Apr 04, 2022Aspirant
I agree, removed it this am, after it was found again on my router log as having being accessed.
