dcac14450
Mar 14, 2022Follower
Netgear92 Connection Not Private
Please advise how I can make my Netgear92 connection private. Tried logging on to my IP address using the User Name and Password that I set up during registration to get instructions on how to fix it to no avail. HELP!!!!
Review the user manual and read up on the Basic/Wireless settings section on how to set the wifi security.
https://www.netgear.com/support/
Make sure WPA2 and AES is set on the routers web page using a web browser.
What do you mean by that?
If it has a strong password it is as private as you will get.
Do you have a problem that you are trying to fix? If so, what is it?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.
