Vijayakumar
Apr 27, 2021Follower
Netgear94, connection dropped frequenty.
I have netgear94. In a day, the connect drops for only few connections. I am using around 8 devices. Couple of devices are not getting connected. Other devices are working fine. Once I restarted the router, it works. Can sombody suggest what could be the issue?
1 Reply
What actual router do you have? Netgear64 is the wireless ssid name. Not a model
What modem/gateway is it connected to?
What firmware is on the router?
