Oktayey's avatar
Oktayey
Network Connection Issue: "The router cannot connect to the Internet with the current settings."
I just switched to a WNR1000v3 hooked up to an SBG6580 router/modem whose WiFi seemed to be unreliable, and I've been experiencing a strange problem where I can visit websites just fine, but I can't ping urls via command prompt, run speed tests, or join CSGO matches.
In the Netgear router's 'basic' home, all areas appear green besides 'Internet', which says "Not connected". Clicking 'Internet' takes me to a loading page that says "Detecting the Internet Connection", then "Applying Internet Connection Settings", before it lands me at an error page that reads:
Please review the following items:
  • Check that the cable connections are correct. Refer to the router Installation Guide for instructions.
  • Check that your broadband modem is power cycled correctly. If you have a battery-backed modem, remove and reinsert the battery to power cycle your modem.
It then gives me two options: to try again (which gives the same result), or to "configure the Internet connection myself" (in which all the options on the landing page already look fine).
The 'Advanced' home, on the other hand, displays everything green (except 'Guest Network', which I have disabled).
The router is running on firmware V1.0.2.78_60.0.96NA, the latest available version, and I have already tried rebooting it many times.
  • > I just switched to a WNR1000v3 hooked up to an SBG6580 router/modem
    > whose WiFi seemed to be unreliable, [...]
       It's tough to believe that an antique like that could be the solution
    to any ordinary wireless-network problem, but...
       "hooked up" how, exactly?  If the [ARRIS?] SBG6580 gateway is (still)
    configured as a (modem+)router, then it would probably be wise to
    configure the WNR1000v3 as a wireless access point, rather than as a
    full-function router.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.
       When I did that, I didn't see a simple WAP option, but almost any
    wireless router can be configured that way.  See, for example:
          https://community.netgear.com/t5/x/x/m-p/1463500
       That's written for a Netgear C6300-as-WAP, but the steps are about the
    same for any other router (any make/model) which lacks a one-step WAP
    option, including your antique.
       Note that that scheme leaves the WAN/Internet port on the
    router-as-WAP unconnected.  (A WAP is all-LAN.  A model with the
    one-step WAP option effectively reconfigures its WAN/Internet port as
    another LAN port.  Without the one-step WAP option, you need to use only
    the LAN ports.)
       General advice:
    > [...] I can't ping urls via command prompt [...]
       "can't" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.  Especially when using a command-line
    program, copy+paste is your friend.
    > [...] seemed to be unreliable, [...]
       "seemed"?  "unreliable"?  See "not a useful problem description
    [...]", above.
    • Oktayey's avatar
      Oktayey
      I can't really try to troubleshoot the original device since it isn't mine.
      I tried setting the WNR1000v3 into access point mode like you suggested, and while my initial problems are now gone, the connection speed is stuck at ~2.5Mbps up/down when they were ~10Mbps previously.
      Every ping attempt timed out, resulting in a loss rate of 100%.
      [...]", above.
      I didn't go into detail about the reliability problems because I figured an issue with the original device's WiFi isn't relevant, seeing how I'm no longer using it, instead using CAT5 to connect it to the WNR1000v3.
