WildBill97
Oct 16, 2021Follower
Network Connection
*EX3700 My extender is setup and working and connected to my PC. The extender is setup on a separate SSID from my primary network. I note that whenever I shut down/restart my PC the Extenders network...
- Oct 16, 2021
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-systemThing helpful to inlude in that forum is Brand and Model# of host wifi router.
FW version loaded on the EX unit.
Distances between EX unit and main host wifi router.
Wifi channels used.
Thank you.
Oct 16, 2021Guru - Experienced User
Wifi channels used.
Thank you.
