oldbadger14
Jun 28, 2021Aspirant
Network Connectivity
I recently rebuilt my PC and now when I use File Explorer the netgear box shows up as Storage, but I can't reach it. It use to show up under Network (but in File Explorer it was under the label Compter).
I have no clue why this is happening and I was hoping this forum could lend a hand.
Many thanks,
BLP
> I recently rebuilt my PC [...]
Does that mean a fresh Windows installation? Did you declare the
(new) network connection to be Private? Windows (Firewall) normally
blocks file-sharing over a Public network connection.> Model: RNDP400U|ReadyNAS Ultra 4 Plus Chassis only
- oldbadger14Aspirant
Yes, I formatted the drive and put a new fresh version of the OS on my c-drive. Yes, I did check the network sharing options and I did check mark private.
Thanks for asking - any thoughts?
BLP
