NIHill's avatar
NIHill
Network Disappears when connecting wrieless printer via WPS button
I have a WNR2000 v3 router. When I try to set up my wirless printer via push button method, the printer connects, but then my wireless network disappears. In it's place, there is a password protected...
  • NIHill's avatar
    NIHill
    Sep 30, 2015
    Yes, I had to reset the router to factory settings and then manually set it up. Worked. Just confused becasue auto setup worked great when I first set up the printer earlier in year.
