dadus33's avatar
dadus33
Follower
Nov 20, 2020
Network failing on high speed download
I have a gigabit fiber connection from my ISP. Before buying this router (a Netgear R6220), I used to connect directly to their gateway (a ZTE ONT which also acted as a router with AP), however I soon had issues with it simply dying on me when downloading at high speeds (nowhere near the gigabit level tho, it would usually break at around 400-500 Mb/s tho it would sometimes hold longer), and the only way to get it back up was to reboot the gateway. Needless to say, this got pretty annoying soon, and after having a talk with one of the ISP's technicians, they suggested setting up an actual router to let the ONT work in bridge mode and have the router use the LAN1 port of the ONT as it's WAN port, effectively letting the router do the AP and routing part that the ONT was previously also doing.
I bought the Netgear R6220 router, and at first it seemed to have worked. I managed to get 115 MB/s down the day I set it up the first time, and was pretty happy. However, I realized that soon after reaching said speed the network failed again. This time both the ISP provided gateway and the Netgear router were still working and didn't have to be rebooted, but I couldn't access either from the PC I reached those speeds on until after about 2-3 minutes, time in which the WiFi on other devices throughout the home was working fine (I don't have any other wired devices so I can't say if those would have worked). As soon as I could access the router and the internet again, I did a speed test and it looked as if I was capped at 100Mb/s. I logged in into the router and I found this:
(The uptime was actually less than a minute back then, but I just took the screenshot now)
Restarting the router resets the status to 1000M/Full, but I don't know any other way of doing this. Also, this has happened multiple times (5 in the space of just 2 days), and sometimes at much lower speeds too (600 Mb/s).
So, the question would be, how can I make sure if this is a router or a PC problem (or perhaps something else)?
No RepliesBe the first to reply
