Jeremy-W
Jun 29, 2016Aspirant
Network gone after factory reset on WNDR3400v2
I had to factory reset my router because I forgot the password. After I did so, my network is no longer working. I cannot connect my windows tablets to my PC and vice-versa. They cannot see my PC and...
- Jul 05, 2016Thank you for all your help, but I ended up buying a new router and set it up and that fixed the problem. I'm sure there was a solution but after hours of time spent on the phone with tech and reading countless articles on how to fix it with no results, I went that route and saved myself more hours of countless headaches.
Jeremy-W
Jul 05, 2016Aspirant
