Forgeahead
Sep 16, 2021Guide
Network layout improvement
I have the following network layout, with Windows 10. The internet is accessed thru comcast. The WNDR4300 is hard wired to my computer and to the WNR2020 which is in the front of the house. The ente...
- Sep 17, 2021
Thank, sounds like you have upped your system to WIFI 6. Pretty sure that would not help me due to Cable limits. Sounds nice though.
Will I be able to tie in my printer to the Orbi system with the Netgear ReadyShare app?
Sep 16, 2021Guru - Experienced User
You didn't give us much.
1. what modem do you have from comcast?
2. is it only devices connected to the wnr2020?
3. is the wndr2020 in router or access point mode?
- ForgeaheadSep 16, 2021Guide
I have a Zoom 3.0 Series 1094, Model 5341J bringing in the comcast signal.
Only problem is connectivity to the WNR2020.
and the WNR2020 is in Router Mode
Actually I went back to that computer in the front room and noticed that when I logged in it actually took me to the WNDR4300 which is in Router Mode. I am not sure about the WNR2020 since when I try to log in with 192.168.1.1 I only get to the 4300
- michaelkenwardSep 17, 2021Guru - Experienced User
You have (at least) two routers on your network. the above it seems that both the WNDR4300 and WNR2020 are in router mode.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.Fortunately, the Zoom device appears to be a simple modem.
Before you start worrying about fixing IP addresses, it might be a good idea to deal with the double-NAT issue. This may solve the problem with errant phones. But when it comes to connecting to wifi, that is down to them, the wifi clients. The routers just provide wifi. Devices that old – both date back more than five years – are not smart enough to control what the various clients get up to. For better management of that you may need to invest in something smarter, such as a Mesh system.
