Forgeahead
Sep 16, 2021Guide
Network layout improvement
I have the following network layout, with Windows 10. The internet is accessed thru comcast. The WNDR4300 is hard wired to my computer and to the WNR2020 which is in the front of the house. The ente...
- Sep 17, 2021
Thank, sounds like you have upped your system to WIFI 6. Pretty sure that would not help me due to Cable limits. Sounds nice though.
Will I be able to tie in my printer to the Orbi system with the Netgear ReadyShare app?
Sep 17, 2021Guru - Experienced User
the orbi system will perform about the same in terms of peak performance as the R6900p (pretty sure you mean that router) but will have much better coverage. Its a solid system from my experience.
Forgeahead
Sep 17, 2021Guide
