zak55
May 14, 2023Follower
Network Map, how to switch from 2.4 to 5.0 map
I have a R6300v2 — AC1750 Smart WiFi Router Dual Band Gigabit, Model / R6300 v2. Version 2.4.62
This Router is working very well and my devices are connected and functioning well.
#1. I can see the Network Map for the 2.4 but I can not figure out how to switch to see what devices are on the 5.0.
#2. On the WiFi Connection box it shows status, "Not Enabled". What does this mean exactly and if it needs to be Enabled, how do I do that?
Thank you.
1 Reply
Where is this map you refer too?
Post a screen capture please.
Is this the Nighthawk mobile app?
