brokenrouter702
May 06, 2022Follower
Network port capped at 100mbp
I've seen countless threads on this here and none have provided an answer. I have an ARIS Surfboard cable modem SB8200 I have the netgear R6080. When I run a speed test the most I can get is 100mbp I...
Kitsap
May 06, 2022Master
The Ethernet ports on your R6080 router are rated at 10/100Mbps. See attached catalog snip from Amazon.
Now you know why.
