brokenrouter702
May 06, 2022Follower
Network port capped at 100mbp
I've seen countless threads on this here and none have provided an answer. I have an ARIS Surfboard cable modem SB8200 I have the netgear R6080. When I run a speed test the most I can get is 100mbp I...
May 07, 2022Guru - Experienced User
Kitsap is correct. You didn't buy a gigabit router. You bought a fast ethernet router which only has 10/100mbps ports and not gigabit.
So your speed is going to max out at 94 (ish) mbps. If you want faster speeds, you need to upgrade to a gigabit router. And if you're using gigabit speeds, I wouldn't buy a base model gigabit device as even through struggle to hit gigabit over wired if you're using any extra features (armor, parental controls, access controls, traffic monitoring).
