jschristie
Jun 01, 2016Aspirant
Network Security Key
I am trying to change my network key and it doesn't allow me or the previously set password is still there, i have tried to reset my router and still it takes the default password and doesn't allow m...
- Jun 04, 2016
No Luck.. i think i have to bear with it or might have to replace the router.. However, i didn't try downgrading, since flashing itself didn't help.. i dont think downgrading will help.. may be some ROM in the router isn't flashing the memory or resetting the password.. Anyway this router has been working without any issues for more than 4years.. i guess its time to change..:(
jschristie
Thank you, i will try that. Yes, i am running on latest version which is set to automatic update.
When you say use that, i have to just browse to the path where i have saved and click ok, or do i have to do anything else apart from that?
ElaineM
Jun 01, 2016NETGEAR Employee Retired
That's correct. Just browse the file and upload. Just don't forget to reset after loading the firmware.
Resetting the router will require you to configure it again as if it's brand new out of the box.
- jschristieJun 01, 2016Aspirant
- ElaineMJun 03, 2016NETGEAR Employee Retired
Is it successful?
- jschristieJun 04, 2016Aspirant
