jschristie
May 31, 2016Aspirant
Network Security Key
I am trying to change my network key and it doesn't allow me or the previously set password is still there, i have tried to reset my router and still it takes the default password and doesn't allow m...
- Jun 04, 2016
No Luck.. i think i have to bear with it or might have to replace the router.. However, i didn't try downgrading, since flashing itself didn't help.. i dont think downgrading will help.. may be some ROM in the router isn't flashing the memory or resetting the password.. Anyway this router has been working without any issues for more than 4years.. i guess its time to change..:(
Tennille
Aug 11, 2016Aspirant
Would you be able to help me Elaine? I can't figure out how to change my password or even figure out what my router is called because there are many other net gear routers in my area!
ElaineM
Aug 12, 2016NETGEAR Employee Retired
Tennille You may want to verify the wireless settings of your network by accessing the admin page of the router using a wired computer that is directly connected to the router.
I suggest that you change the name of your wireless network name in order to identify your own network and secure it using WPA2 type of security.
Kindly see the link below for troubleshooting.
How do I change my NETGEAR router WiFi password or network name (SSID)?
