actinia
Aug 12, 2015Aspirant
Network unstable
I am experiencing daily unstabilty on my R6300v2 FW version V1.0.3.30. My devices appears to be connected, but nothing happens when I try to open websites, and when I try to open NETGEARGenie on my...
- Aug 19, 2015
Looking at the description of the centrino wireless adapter, it will only work on 2.4ghz.
You may wanna try disabling and enabling SSID broadcast on the 5ghz. When you access the router page, look for the 5ghz and uncheck it then click Apply. After it's done saving, enable SSID broadcast once again.
If the same thing happens, reflash the firmware of your router.
actinia
Aug 19, 2015Aspirant
I´ll try having my mac connected to the 2.4 ghz for a while, and see what happens.
My windows 7 computer has an intel centrino wireless-n 1000 card, which seems to only connect to the 2.4 ghz.
Are there any fixes if the 5ghz on the router is the problem? The router is just a few months old, and has had these hiccups since I bought it..
doraemon
Aug 19, 2015Prodigy
- netwrksAug 19, 2015Master
actinia Ensure WMM is enabled on the router, (Macs need it) close the Genie app, on your Mac. Genie can cause numerous perfomance issues on the router. When you logon to the router, use a browser.
- actiniaAug 22, 2015Aspirant
WMM was enabled. I´ll kill the Genie app and only use the browser..
