actinia's avatar
actinia
Network unstable
I am experiencing daily unstabilty on my R6300v2 FW version V1.0.3.30.  My devices appears to be connected, but nothing happens when I try to open websites, and when I try to open NETGEARGenie on my...
  • doraemon's avatar
    doraemon
    Aug 19, 2015
    Looking at the description of the centrino wireless adapter, it will only work on 2.4ghz.
    You may wanna try disabling and enabling SSID broadcast on the 5ghz. When you access the router page, look for the 5ghz and uncheck it then click Apply. After it's done saving, enable SSID broadcast once again.
    If the same thing happens, reflash the firmware of your router.
