db4819
Feb 03, 2025Tutor
New Gateway and Access Point
 I recently upgraded my gateway to an XB8 from Xfinity and as a result, one of my older laptops will not connect wirelessly. The ethernet works fine. I was told by Xfinity that I could use an old rout...
- Feb 03, 2025they make the nano adapters (a bit shorter range) that don't stick out very far.
Feb 03, 2025Guru - Experienced User
What actual wireless card is in the laptop?
Might be worth checking into upgrading the wireless card or even using a USB wireless card
db4819
Feb 03, 2025Tutor
It's an Intel centrino wireless-n 1000. The laptop is an old Lenovo Z570 Ideapad that used to connect by wireless just fine....until I upgraded the gateway. The laptop is old enough that I'm not sure if an internal card replacement is available. I tried to ask Lenovo, but they had no advice.
- plemansFeb 03, 2025Guru - Experienced Usermaybe not something worth it but you can get a usb based one. That'd be a better option than adding a 2nd router that can add interference. Pretty cheap too. You can snag a half decent one from old jeff b for that $10-20 - db4819Feb 03, 2025TutorThanks for your help. I'm beginning to think that as well. I'll start checking out what they have. Just didn't want something large sticking out the the side of the laptop. Thanks again! - plemansFeb 03, 2025Guru - Experienced Userthey make the nano adapters (a bit shorter range) that don't stick out very far.
