db4819
Feb 03, 2025Tutor
New Gateway and Access Point
I recently upgraded my gateway to an XB8 from Xfinity and as a result, one of my older laptops will not connect wirelessly. The ethernet works fine. I was told by Xfinity that I could use an old rout...
- Feb 03, 2025
they make the nano adapters (a bit shorter range) that don't stick out very far.
Feb 03, 2025Guru - Experienced User
maybe not something worth it but you can get a usb based one. That'd be a better option than adding a 2nd router that can add interference. Pretty cheap too. You can snag a half decent one from old jeff b for that $10-20
db4819
Feb 03, 2025Tutor
Thanks for your help. I'm beginning to think that as well. I'll start checking out what they have. Just didn't want something large sticking out the the side of the laptop.
Thanks again!
- plemansFeb 03, 2025Guru - Experienced User
