JayBuck68
Aug 16, 2024Aspirant
New ISP at apartment building. No modem, just Ethernet wall jack. Setup?
I have an AC1750 Wi-Fi Router (R6400v2). We just got a new ISP at my apartment. We no longer have a modem. They put Ethernet port (not sure if that's the right term) in the wall. Their instructions we...
- Aug 25, 2024
It was something that was messed up on their end. I was nervous because they said if it was due to user error (i.e., "my fault"), they would charge $75 for the technical assistance.
michaelkenward
Aug 17, 2024Guru - Experienced User
JayBuck68 wrote:
All the instructions I find talk about using a modem, which I don't have. I'm not able to connect to the Internet.
The instructions they've given don't provide much detail.
Do they offer any login details for your account? Username and password?
It depends on what sits at the other end of that wall socket and how the Internet gets to you. If it is fibre all the way, then it could be a simple case of plugging it into the Internet socket. Reset the R6400v2 before you try that.
If this fails, then one option is to put the R6400v2 into Access Point mode.
Just another user with time on their hands.
- JayBuck68Aug 25, 2024Aspirant
- michaelkenwardAug 25, 2024Guru - Experienced User
So it is fixed now?
Yes. Thanks for your suggestions.
