Trogdor
May 06, 2016Aspirant
New R6400 does not see internet on install
I'm attempting to upgrade from an N300 router to a R6400 router. On install, the R6400 does not see the DSL modem (Speedstream 5260), I'm using the same wiring for both routers only disconnecting a...
- May 13, 2016
The new router arrived and the installation was smooth as silk. Everything up and running great!!
DexterJB
May 11, 2016NETGEAR Moderator
Hi Trogdor,
1. Can your computer go online while connected straight to the Speedstream modem without any additional configuration on the computer?
2. Have you tried configuring your ISP's DSL settings (username and password) on the router UI?
Dexter
Community Team
- TrogdorMay 11, 2016Aspirant
Just got off of the phone with teh help center. Went through all of the exact same stuff as I did with first router, no joy. They have given me a new RMA# and will be paying shipping this time.
To answer you questions:
1. Yes, I can connect to the internet directly via the Speedstream modem. But I'm currently typing this via a Netgear N300 WNR2000 v3 router connected through the Speedstream.
2. Yes, tried configuring via the Netgear Genie, & tried forcing the same numbers used by the WNR2000. After applying the settings, looking at the Genie in the advanced setting for Internet, The number seen in the Internet Port box are all zeros.
