rinn
Aug 22, 2017Aspirant
New R6400v2 not recognizing ethernet cable; no internet connection
I just bought a new R6400v2 AC1750 Smart Wifi Router, and it worked fine the first day I set it up. However the second day it suddenly stopped working. I logged into the router's IP address and it sa...
- Aug 24, 2017
Hi rinn,
Please try doing a loop back test to check if the WAN port of the router is still working. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/28408
Dexter
Community Team
DexterJB
Aug 28, 2017NETGEAR Moderator
Hi rinn,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- rinnAug 28, 2017AspirantThanks Dexter. I did the loop test and it appeared that the WAN port was not working. Luckily the router is under warranty.
Thanks for your help! - JohnsamuelSep 20, 2017AspirantHi i am facing the same issue but my wan is working
- DexterJBSep 20, 2017NETGEAR Moderator
Hi Johnsamuel,
1. Did you do the loopback test?
2. Have you tried resetting the router?
3. Have you tried changing the Ethernet cables?
Dexter
Community Team
- Y11Sep 24, 2017Aspirant
I too had the same problem. I hooked up the router to my modem, Comcast issued, and it worked great. I then changed modems, Surf Board SB6190, and the router quit. I checked the modem by connecting directly to my computer and it workes great. The modem does not pick and chose to not work with other routers. The router is seen by my computer when hooked directly to it and so is wifi seen by my other wireless units but I get no IP address now. I did the loop test and it looks as if it failed. I did the factory reset and tried rebooting the system several times. Is this a bad unit now and is this a product that will have problems after it is replaced? When it worked, it had great range and was, as I had plan, to be a much better unit than the Comcast supplied modem/router. Send it back for replacement?
