Az1004's avatar
Az1004
New router can't connect to internet
Hi, I got this new router and I want to replace my old one. I connected the cables I was using for my old router, and connected to this new one(this includes 1 white ethernet cable from the wall to p...
  • antinode's avatar
    antinode
    Jul 14, 2020
    > [...] It's an att uverse 5628ac. [...]
       "5268AC"?  That (almost) answers one of the many questions.  What
    about the others?  Look for "?".
    > [...] I got a 2 month used router from someone I know, so I'm trying
    > to switch to that one.
       I doubt that it's suitable.  As I understand it, the co-ax connector
    on an 5268AC is used to connect to some old-style client devices.  The
    co-ax connector on a C6250 is used to connect to the (cable-TV) ISP.
    Not even similar.
       Also, because you're not using the "DSL Broadband" port, the cable to
    the "ONT Broadband" port (from your "the wall" I'd guess?) must be your
    connection to your ISP, and a C6250 has no Ethernet WAN/Internet port,
    making it useless as a replacement for a 5268AC.
       Nice try, but you seem to be in a square-peg/round-hole situation.
    You want a friend with a plain-old router (with an Ethernet WAN/Internet
    port), not a cable modem+router (with a co-ax WAN/Internet port).
