Az1004
Jul 15, 2020Aspirant
New router can't connect to internet
Hi, I got this new router and I want to replace my old one. I connected the cables I was using for my old router, and connected to this new one(this includes 1 white ethernet cable from the wall to p...
- Jul 15, 2020
> [...] It's an att uverse 5628ac. [...]
"5268AC"? That (almost) answers one of the many questions. What
about the others? Look for "?".> [...] I got a 2 month used router from someone I know, so I'm trying
> to switch to that one.I doubt that it's suitable. As I understand it, the co-ax connector
on an 5268AC is used to connect to some old-style client devices. The
co-ax connector on a C6250 is used to connect to the (cable-TV) ISP.
Not even similar.Also, because you're not using the "DSL Broadband" port, the cable to
the "ONT Broadband" port (from your "the wall" I'd guess?) must be your
connection to your ISP, and a C6250 has no Ethernet WAN/Internet port,
making it useless as a replacement for a 5268AC.Nice try, but you seem to be in a square-peg/round-hole situation.
You want a friend with a plain-old router (with an Ethernet WAN/Internet
port), not a cable modem+router (with a co-ax WAN/Internet port).
Az1004
Thanks for your help. So since the internet is coming through the ethernet cable, not the coax cable, I need a router that uses an ethernet port for internet connection. Did I understand it right?
antinode
Jul 15, 2020Guru
> [...] Did I understand it right?
It seems so.
There could still be some fine-print requirements (about which I know
nothing) involving use of a user-supplied router with your ATT U-verse
service, but a cable modem+router has no chance.
