zekgrafic
Jul 21, 2022Follower
New router gives slower speeds
My C6900 router died so I got a CAX30, but my downloads speeds via ethernet went from 50MB/s (megabytes not bits) to a maximum of 20MB/s. The only time this changes is when I unplug the router and ...
Jul 21, 2022Guru - Experienced User
The CAX30 should easily max out that connection.
What firmware is on it?
You do get the full speeds after a reboot?
Do you have a screen snip of your cable connections page and the event logs?
