fpefpe
Dec 12, 2021Aspirant
new version?
Hello --- I have the GS108 switch --- I see there is now the GS308 -- and the 108 is EOL ---- is the 308 and update to the 108 Thanks
Dec 12, 2021Guru - Experienced User
Review the spec sheets for each to compare HW differences.
https://www.netgear.com/support/
Input each model #
Netgear has set up a community forum specifically for the LAN Switch products. Most of the people who watch that forum are more likely to have experience with Switch products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Unmanaged-Switches-Forum/bd-p/business-unmanaged-switches
Thank you.
fpefpe
thanks for the info
- plemansDec 12, 2021Guru - Experienced User
Both are simple unmanaged switches. You aren't going to see much (if any) of performance differences between the 2.
If you're looking at upgrading just for a newer version, the money would be better directed for future upgrades to the router or to a 2.5gig or managed switch.
