fpefpe
Dec 12, 2021Aspirant
new version?
Hello --- I have the GS108 switch --- I see there is now the GS308 -- and the 108 is EOL ---- is the 308 and update to the 108 Thanks
fpefpe
thanks for the info
Dec 12, 2021Guru - Experienced User
Both are simple unmanaged switches. You aren't going to see much (if any) of performance differences between the 2.
If you're looking at upgrading just for a newer version, the money would be better directed for future upgrades to the router or to a 2.5gig or managed switch.
