annodomini
Dec 27, 2019Aspirant
New Xfinity Modem and Access Point Problems
Internet service from Xfinity for four years. Arris TG862G/CT modem in home office, cat5 length of the house to living room (30-40 feet) connected to an RC6220 AC1200 router. Wireless signal directly...
- Dec 28, 2019
Distance does matter a bit. What type of cable is it? Cat 5, cat5e, cat6, cat7?
And if moving the router to the modem makes it work, i'd be taking a hard look at that cable
Dec 27, 2019Guru - Experienced User
Its because you're in a double nat. You're running 2 routers on a network.
https://kb.netgear.com/30186/What-is-Double-NAT
the 2 easiest fixes is to either want to place the arris in passthrough/modem only mode or place the netgear in AP mode.
annodomini
Not that. Everything worked fine with the same equipment for four years. The RC6220 AC1200 was in wireless access mode.
