annodomini
Dec 27, 2019Aspirant
New Xfinity Modem and Access Point Problems
Internet service from Xfinity for four years. Arris TG862G/CT modem in home office, cat5 length of the house to living room (30-40 feet) connected to an RC6220 AC1200 router. Wireless signal directly...
- Dec 28, 2019
Distance does matter a bit. What type of cable is it? Cat 5, cat5e, cat6, cat7?
And if moving the router to the modem makes it work, i'd be taking a hard look at that cable
annodomini
Dec 28, 2019Aspirant
Some more info. physically brought the exact same RC6220 to the modem and plugged it in with a three foot run of cable, and it acquired the internet without issue. is it possibly the length of the cable run? it's about 30-40 feet to the living room but I believe it is a 50 foot cable (to get around corners, doors, etc). as stated, same cables worked fine one minute, no internet when reconnected to the new modem.
Dec 28, 2019Guru - Experienced User
- annodominiDec 28, 2019Aspirant
gotta be honest and say it was the cheapest stuff I could get my hands on. I looked at the cable itself and there is absolutely nothing printed on it. don't remember where I bought it. do know that it's either cat5 or cat5e
- plemansDec 28, 2019Guru - Experienced User
Again, if it works with a different cable, I'd be looking at that cable as the culprit. Might have to move it closer for the time being.
