pses530
May 05, 2017Aspirant
Newbie question using extender?
Hello, My router the N300 WNR2000v3 is located in my basement and the signal strength is low when multiply users are on the network. Before I move it upstairs I wanted to ask about using the...
- May 26, 2017
michaelkenward
May 06, 2017Guru - Experienced User
pses530 wrote:
Before I move it upstairs I wanted to ask about using the N300 wifi extender. Is this a better option?
There are many N300 wifi extenders. That's a wifi speed standard.
If devices have trouble connecting to the basement wifi, maybe the extender will too if you plan to use it as wireless extender. Unless you plan to wire the two together and use it is an access point to broadcast the wifi.
One way to bring wifi to other places is to get a powerline device that also has an access point.
pses530 wrote:Also my routers firmware isn't the latest version should I update it ?
Yes.
