pses530's avatar
pses530
Newbie question using extender?
Hello,   My router the N300 WNR2000v3  is  located in my basement  and the signal strength is low when multiply users are on the network.   Before I move it upstairs I wanted to ask about using the...
  • pses530's avatar
    pses530
    May 26, 2017
    Hi michaelkenward
    I picked up the R7000 last night.
    Thank you for all your help.
    Pete
