Needtoknow1's avatar
Needtoknow1
Follower
Nov 27, 2016
Newly installed AC1750 R6400 wont show 5G network
I installed a new Netgear AC1750 router last night, model #R6400. The 5G light is on and settings say it is enabled but it will not show up as an avaliable network. My 2.4 network shows but not the 5...
  • DexterJB's avatar
    DexterJB
    Jan 05, 2017
    Hi koreo1108,
    You can try the following steps:
    1. Change the wireless channel for the 5GHz band. You can use a WiFi analyzer app/program to check for the best channel.
    2. Make sure that the 5GHz LED is lit.
    3. Press the WiFi on/off button on the device.
    4. If the issue persists, re-flash the router's firmware then reset and reconfigure the settings.
    Dexter
    Community Team
