john1966
Jul 06, 2021Guide
Nighthawk 2300 can't connect to guest network
Today both me and my guest are no longer able to log into the guest network. 1) Only on the 2.4 GH .. the 5GH seems to work for log in. 2) Nighthawk 2300 3) Several devices can't log o...
john1966
Jul 06, 2021Guide
Thank you for the reply and suggestion.
The 2.4 and 5.0 GH works for the main non guest network. I haven't done a factory reset and reinstall. Would I need add all the devices again and enter the passcode? If so I would need to wait until tomorrow when I don't have a guest so I can access some of the devices like the guest TV which is on the non guest network. Anything else I could try?
Jul 06, 2021Guru - Experienced User
You can always try a simple reboot.
If you reset and use the same ssid/password for setup, devices should just auto-reconnect. *should*
I replace/reset routers frequently and haven't had to re-add a device in years. I simply use the same ssid/password
- john1966Jul 06, 2021Guide
Wanted to add that the main network was also having trouble signing iin with my iphone. I run a B&B and its essential for guest to not have any wifi problems. I try and factory reset it all tomorrow, but the complete lack of customer support for something under warranty is very disapointing. I'm thinking I'll proably just need to get a diffrent routher that honor's the warranty. The follow up email I got said to click a linik to report that the issue wasn't resolved yet but that also didn't work.
Appologies for the frustration. Any adivice is appreciated. I just need it to work and can't have any issues with signing in.
BTW I even tried removing the password so no password was required but still wouldn't sign in. And now main network is also acting up.
- plemansJul 06, 2021Guru - Experienced User
What firmware is on the router?
What modem/gateway is it connected to?
In terms of support, sadly many companies are moving to/moved to the model of free support for 90 days. You still have a hardware warranty for hardware failures. But most consumer networking gear has lower margins and so the actual support is only for when your first purchase it to get it running. Help with settings/setup past that 90 days costs money because they can't afford to be an IT department for consumers. Its also why you find many consumer networking companies have forums for free help.
The firmware is V1.3.1.64_10.1.36
The modem is a Arris SB8200 I beleve, one of their faster ones but that doesnt' seem to be the issue.
The only reason I think this is a defective product is that only the 2.4 GHZ on the guest network is not working as it should. So it seems like its a software bug on their end.
Once again appreciate the suggestoins. Frustrating to get a message from my guest that wifi wasn't working. That's very important for gueet so will have to buy anoher new one if I can't get it working like it has been for the past 8 months.
I've tried a simple reboot and waited 5 minutes with both roter and modem unplugged. I followed the reboot instructions but same problem.
If I do factory reset I suppose the devices would remember the same passwords but will try it tomorrow wihen its empty. If that doesn't work, I'll simply have to cut my looses.
