Ann743
Feb 07, 2025Aspirant
Nighthawk AC1000
Last night I set up my router to turn off at night & turn back on in the morning. It never came back on. I don't have anything hard wired, so what do I do to get back into the router settings to de...
Ann743
Thank you for replying & sharing the information. It is the R6080. I only use speeds of 100 & its plenty for what I do, but I am looking for new router online now. The additional issue is I need something fast, like today or tomorrow at the latest fast. Do you have any suggestions of what would be similar in set up as this one, so I can learn to set it up & change passwords & program the on/off times? I do have one camera monitor for dog sitting that uses the older frequency of 2.4, so the dual frequency was nice. But I suppose I could get a newer camera as well. Sigh...
Ann743
I forgot to mention I did turn the router & modem off & back on in the sequence you mentioned, but I did not turn off the devices connected to them. The Modem is from Spectrum. I can't give the specifics on it, because I'm not home now.
- Ann743Feb 07, 2025Aspirant
So I just ordered the Nighthawk Wifi 6 Router RAX54S from Amazon. It says it will be here tomorrow morning. Hopefully its a good upgrade & that I can learn it quickly. Maybe I can experiment with programming the settings to turn off just one of the bands at night first, so I can use the other band to get back into the settings if something goes wrong with my initial attempt. Bummer about the old one. I just spent a lot of time yesterday learning about how to set it to go off at night & on in the morning. Maybe the learning curve will help with the new one.
Now I don't think what I just purchased in a panic is not going to work. The reviews state that an app is required to set it up & that you need to be connected to the net on your phone to use the app. So for someone like me that doesn't have a hard wired way to connect, that won't work.
- michaelkenwardFeb 08, 2025Guru - Experienced User
You can set up the RAX54S in the same way that you set up the R6080.
Every device from Netgear now talks about using the app for set up. That is not essential.
And the controls on your new router will be very similar to the old one.
Visit the support pages:
Support | NETGEAR
Feed in your RAX54S model number and check the documentation for your hardware.There may also be some helpful videos on what to do.
Begin with the Quick Start/Installation Guide. And download a copy of the manual.
Check the section in the manual Use a web browser to access the router
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.Anything in the box with the router will refer to the Nighthawk app. Many experienced users prefer the manual approach. But don't be intimidated by the app. It can have its uses.
You say that you don't have a wired connection. You can also use a web browser on your WiFi device to get in there. Just connect to the WiFi using the SSID on the default details on the new router. Then take it from there.
Just another user with time on their hands.
