Strat1
Apr 04, 2022Tutor
Nighthawk AC1750 (R6400)
I've never been abused by customer service until last night. The thought never entered my head. What started my day off was my internet abruptly stopped. I switched out a couple of cables, still noth...
- Apr 06, 2022Interesting. Something else to watch out for. The number i called was in a netgear app. When it couldn't connect, it prompted me to call the number. I guess that was probably a decoy app. You definitely can't be too paranoid anymore.
So I pressed one of those lit lights on the right side of the night hawk, everything's back to normal now. My cat walks behind my TV all the time, he might have pressed the button. Thanks!
michaelkenward
Apr 05, 2022Guru - Experienced User
Strat1 wrote:
He also said I needed to buy Netgear Security to get it up and running. I said I dont want it. Then he said I'm out of luck.
There's the clue. There is a very high probability that you were not talking to Netgear.
Let me guess, you did a search on something like "Netgear support". Then you called the number that you found.
If that is the case, you probably hit one of the various scam merchants out there who have nothing to do with Netgear.
If you can provide details of the number you called, or the website you found, we can tip off Netgear so that it can throw its lawyers at these crooks.
I hope you didn't allow these people anywhere near your network. If you did, then run as many security scans as possible.
If you still have problems, and you pare out of the 90-days free setup support, try this place.
Netgear does not actually run a support service. It handles that through GearHead.
Strat1
Apr 06, 2022Tutor
- michaelkenwardApr 06, 2022Guru - Experienced User
Strat1 wrote:
My cat walks behind my TV all the time, he might have pressed the button.This is not the first time that a cat has turned off the wifi.
They love sitting on top of warm electronic kit.
