Gogle
Feb 11, 2025Aspirant
Nighthawk AC1750 vR6400v2
SOLUTION to white blank screen when using 192.168.1.1 to login into Netgear Nighthawk AC1750 vR6400v2 Wifi router. (All the LED lights were normal.) I got the white blank screen when using a Wind...
michaelkenward
Feb 11, 2025Guru - Experienced User
Gogle wrote:
Windows 7 should work as well. Apparently, newer Windows and/or Java updates caused the problem.
I'm running the latest version of Windsows 11. Not seen any problems.
Must be a firmware thing.
Disclaimer: Just another user with time on their hands.
