FireNet's avatar
FireNet
Nighthawk AC1900 R7000 Wired Port not working
Hi I purchased the Nighthawk AC1900 R7000 today and seemed to install OK on wireless and the required lights on and everything saying that the Internet connection was good. However when I tried it ...
  • wcalifas831's avatar
    Apr 22, 2018
    Try a hard reset of the router by pressing the reset button with a paper clip for 30 seconds. It will be back to default settings see if the ports work. If not maybe you have a defective router. Since you just bought it maybe you can get it exchanged for another.
