epags1
Jan 21, 2023Aspirant
Nighthawk AC1900 setup problem
Replace my old Netgear N600 Model WNDR3400v3 (another post). Re. the AC1900: Followed setup genie and tried to link the old netgear modem wifi names and passwords. After the 'set up' keep getting ...
microchip8
Jan 22, 2023Master
Stop using crappy apps to set up a router, they're not meant for that. Go to http://routerlogin.net or http://192.168.1.1 and properly set up the router.
Oh, and don't you even think of using an app and WiFi to update the router's firmware, unless you *want* troubles
