Vmusic
Sep 09, 2021Follower
Nighthawk AX4 RAX40v2 ReadyShare Doesn’t Recognize Hard Drive…..DOES Recognize Thumb Drive
Hi, I have a new Nighthawk AX4 RAX40 v2 router. I'm running Firmware Version V1.0.2.82_2.0.50. In the web admin panel - which is not labeled 'Genie'; it's just labled Netgear and it has a R...
michaelkenward
Sep 10, 2021Guru - Experienced User
Vmusic wrote:
Is there a size limit on the external drive that can be connected to the back of a Nighthawk AX4 RAX40??? Are there certain "brands" of external hard drives that are or are NOT supported?
ReadyShare is picky as to USB drives it accepts.
This list will give you some clues, although it is far from comprehensive:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
As you can see, it is also out of date, Last Updated- 04/05/2019, and does not cover the RAX range.
This isn't really the best place to ask about those routers, you might do better here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I have found that USB drives that are billed to work on one device will work on others.
For example, reading that the R7000P accepts the Seagate USB3.0 8TB Model: SRD0PV1, I installed one on an R7800. Works just fine.
Windows is also a factor in this picture. It might also be worth reading this:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
