kateew
Dec 31, 2022Follower
Nighthawk not connecting to Daikin adapter
I got a new router (Netgear Nighthawk R6120), and am trying to connect it to my Daikin out of home adapter to operate my air conditioning through the Daikin app. My iPhone wifi recognises the Dai...
michaelkenward
Jan 01, 2023Guru - Experienced User
Your subject says:
" Nighthawk not connecting to Daikin adapter"
You might do better to think of it the other way round. Daikin adapter not connecting to Nighthawk.
That's because the router just puffs out the wifi that your adapter has to work with.
You could start by telling people which Netgear router you are using.
A more details of that this "Daikin AP network" does might also help.
The Daikin app manual says to press the WPS button, but as my router doesn't have a WPS button I'm not sure how else to get them talking to each other.
All Netgear Nighthawk routers have a WPS button. You just have to find it.
Look on the top.
WPS
Possibly far right, next to this one:
WPS
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
