mnmacd
Nov 15, 2021Guide
Nighthawk R6080 blinking green power light
Okay so here's the issue unit is out of warrnaty 1 week ago,, Now it won't work.... I tried to do an update on the router using the Nighthawk app. Now the power light just blinks green, none of th...
Nov 15, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
mnmacd
Nov 15, 2021Guide
not very tech saavy, how do I enable tpft?
