mnmacd
Nov 15, 2021Guide
Nighthawk R6080 blinking green power light
Okay so here's the issue unit is out of warrnaty 1 week ago,, Now it won't work.... I tried to do an update on the router using the Nighthawk app. Now the power light just blinks green, none of th...
Nov 16, 2021Guru - Experienced User
good luck! tftp can be sensitive to timings so if it doesn't work the first time, try a couple more times :)
mnmacd
Nov 16, 2021Guide
WOuldn't work if it was easy....
- mnmacdNov 18, 2021Guide
https://www.youtube.com/watch?v=R9DLrLQrpaw SO got a chance to watch this.. I have a question before I do this though... DO I have to do the ssteps listed here 1st?
https://www.thewindowsclub.com/enable-tftp-windows-10
Still not comfortable doing the nmrp flash....
- plemansNov 18, 2021Guru - Experienced User
Yes. Make sure tftp is enabled before following the guide.
You don't have to use nmrpflash. Its just a 2nd option if tftp doesn't work.
I think I've used nmrpflash 2-3x but thats only been in cases where tftp didn't work.
- mnmacdNov 19, 2021Guide
Another silly question, again not at all tech savvy. WIll my router need to be plugged in during the enabling of of TFTP? , or after.....
- michaelkenwardNov 20, 2021Guru - Experienced User
Clearly you don't need a connection to the Internet because the router is bust and can't provide it.
You do need a connection between the PC and the router. That is how TFTP talks to the router,
Just follow these instructions.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Note the bit about unzipping the firmware file you download before you try TFTP.
- mnmacdNov 21, 2021Guide
MIchaelkenward: In one statement you said I do and I don't need the router on this is a contradiction, so which is it . Please don't be rude...
- plemansNov 21, 2021Guru - Experienced User
Use the .img file. It can either be a .chk or .img file for firmware.
- michaelkenwardNov 21, 2021Guru - Experienced User
mnmacd wrote:
In one statement you said I do and I don't need the router on this is a contradiction, so which is it .You asked
"WIll my router need to be plugged in..."
Plugged into what? Network? Mains? Modem? Internet?
I said you don't need a connection to the Internet. But you do need a connection to the router.
I said that because people have been confused in the past.
I could say the same, or something even more provocative.
These things need to be done properly That means asking meaningful questions and following the answers.
