Rakesh92's avatar
Rakesh92
Nighthawk R6080 not giving max speed over WiFi
I have a Nighthawk R6080 connected to a Arris surfboard SB6183. My Internet speed is 600 mbps. The speed I get over WiFi and via ethernet(connected to my router) is around 100 mbps. I have connected ...
  • plemans's avatar
    Feb 27, 2022
    wcalifas is correct.
    that router is only fast ethernet rated. (10/100mpbs).
    to get faster speeds you'd need to upgrade to at minimum a gigabit router.
    Keep in mind, even if you do upgrade to gigabit, most devices aren't going to hit 600mbps over wireless.
