Rakesh92
Feb 27, 2022Aspirant
Nighthawk R6080 not giving max speed over WiFi
I have a Nighthawk R6080 connected to a Arris surfboard SB6183. My Internet speed is 600 mbps. The speed I get over WiFi and via ethernet(connected to my router) is around 100 mbps. I have connected ...
Rakesh92
Mar 04, 2022Aspirant
Thank you all for your responses, everything just tells that its false advertisement. So, I got myself a WiFi 6 AX 1800 and the nighthawk app says "router not supported". While netgear literally says use nighthawk app.
michaelkenward
Mar 05, 2022Guru - Experienced User
Do not confuse advertised wifi speeds with Ethernet speeds.
Which WiFi 6 AX 1800?
- Rakesh92Mar 05, 2022Aspirant
It is the WAX204. I ave tried every app netgear has now and everything says router not supported. But the support for netgear says nighthawk should do.
- plemansMar 05, 2022Guru - Experienced User
did you try using the broswer portal?
I didn't see in the manual that its supported through the nighthawk app. - michaelkenwardMar 05, 2022Guru - Experienced User
Rakesh92 wrote:
It is the WAX204.
The WAX204 is not a router. It is a Wireless Access Point. It is not a replacement for the R6080.
No sign of it here:
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
The WAX does have a router mode. But its default configuration is access point.
