kn4hh
Nov 25, 2021Tutor
Nighthawk R6400 appears to be blocking some web sites
I have a AC 1750 R 6400 Ver 2 router connected to a Surfboard cable modem. I am running Windows 10. Just recently, I have not been able to log in to a number of web sites and applications that need...
michaelkenward
Nov 26, 2021Guru - Experienced User
Model number for the modem?
There's a lot of them out there, some of them modem/routers.
What firmware do you have on the router.
Do the router's logs give any clues?
Is this question related to your earlier one?
Solved: Re: Just did a Firmware update to my R6400V2 and n... - NETGEAR Communities
PS Unless you have a hardware specific issue, for generic questions like this there really is no need to dive off into another section, where there are far fewer visitors. The main difference between your router and a Nighthawk router is probably the price.
- kn4hhNov 27, 2021Tutor
I thought this might be related to my past problem. I was running Firmware version 1.0.4.120_10.0.91
I went back to version 1.0.4.118_10.0.90 and I still have web site blocking.
Here is the latest log entries.
[Admin login] from source 192.168.1.2, Saturday, Nov 27,2021 09:05:53
[DHCP IP: (192.168.1.4)] to MAC address 98:DA:C4:44:A6:5A, Saturday, Nov 27,2021 08:52:29
[DHCP IP: (192.168.1.4)] to MAC address 98:DA:C4:44:A6:5A, Saturday, Nov 27,2021 08:50:12
[DHCP IP: (192.168.1.4)] to MAC address 98:DA:C4:44:A6:5A, Saturday, Nov 27,2021 08:49:51
[DHCP IP: (192.168.1.8)] to MAC address 26:60:4C:C5:E1:84, Saturday, Nov 27,2021 08:08:17
[Time synchronized with NTP server] Saturday, Nov 27,2021 08:07:37
[Internet connected] IP address: 98.252.157.80, Saturday, Nov 27,2021 08:07:36
[Internet disconnected] Saturday, Nov 27,2021 08:07:35
[DHCP IP: (192.168.1.5)] to MAC address 3C:52:82:71:94:A7, Saturday, Nov 27,2021 08:07:13
[Internet connected] IP address: 192.168.100.20, Saturday, Nov 27,2021 08:07:07
[Internet disconnected] Saturday, Nov 27,2021 08:07:04
[DHCP IP: (192.168.1.6)] to MAC address 2C:D0:5A:49:56:75, Saturday, Nov 27,2021 08:07:04
[DHCP IP: (192.168.1.7)] to MAC address 40:4C:77:CB:05:F3, Saturday, Nov 27,2021 08:06:54
[DHCP IP: (192.168.1.5)] to MAC address 40:4C:77:CB:05:F3, Saturday, Nov 27,2021 08:06:44
[DHCP IP: (192.168.1.4)] to MAC address 98:DA:C4:44:A6:5A, Saturday, Nov 27,2021 08:06:44
[DHCP IP: (192.168.1.3)] to MAC address FC:B4:E6:E1:20:86, Saturday, Nov 27,2021 08:06:42
[DHCP IP: (192.168.1.2)] to MAC address 64:51:06:5A:52:DE, Saturday, Nov 27,2021 08:06:42
[Initialized, firmware version: V1.0.4.118_10.0.90] Saturday, Nov 27,2021 08:06:41This problem exists on all pc runing Windows 10 and 11.
- michaelkenwardNov 27, 2021Guru - Experienced User
See above:
- kn4hhDec 03, 2021Tutor
So sorry for the delay in replying. I finally did a complete system reset and all web sites are now available. However, if I update to formware version 1.2.0.88, the problem returns. I ended up going back to the previous firmware version which cured the problem.
Thank you for the suggestions.
