TonyTorzido
Aug 17, 2022Aspirant
NightHawk R6400v2 has insanely slow Steam download speeds, but fine when connected to modem
I have been having issues with this for 2 years now. I finally decided to try to fix it AGAIN, and no luck. I had tried different firmware version, called Xfinity to see if it was an issue on their e...
TonyTorzido
I have factory reset it multiple times and have zero back ups. I have also tried disabling all the things you listed in different combinations. No luck.
Aug 17, 2022Guru - Experienced User
what device are you testing on?
Does any other device have issues?
- TonyTorzidoAug 17, 2022Aspirant
I have tested this on my PC and my wife's PC. Only devices I use Steam on. Downloads from most other websites or apps are way faster.
Wifi works perfectly fine.
- wcalifasAug 17, 2022Prodigy
If you've tried several firmwares from Netgear and are ready to give up on that router you could always try third party firmware from DD-WRT. I see on the website it is supported but you have to read the instructions to upload the firmware to dd-wrt and download the files there on their website. It's free by the way.
- michaelkenwardAug 18, 2022Guru - Experienced User
So, the PC were wired?
Steam downloads at 15MB/s when connected to the router but goes up to 70MB/s when its connected straight to my modem without the router. My internet speed is 600mbps from Xfinity.
What is that modem?
Did you include this in your research:
Search - NETGEAR Communities – steam
Lots of traffic.
- TonyTorzidoAug 23, 2022Aspirant
Yes, this is all wired. I have tried different wires all CAT6 or higher.
No luck still. I might just have to buy a cheaper router from another brand.
